sigep999 wrote:
I have 2016 Chevy Tahoe.
8600 towing capacity
1000 hitch capacity
5.3 with max trailering package
using a e2 hitch sway system can I safety tow a RV that weights?
6845 dry weight and 845 tongue weight
bumper to hitch 35 FT
IMHO: Short answer... "NO", not safely.
First of all there is little chance you can actually tow something even approaching 8,600#. Towing capacity is as useless a statistic as "dry weights" and both can get you into a world of trouble.
First check your Tahoe's payload. From that subtract 1,040# {your actual tongue weight computed at 13 per cent of the loaded weight of your trailer and everything in it}, assuming you, like most folks will load at least 1,000# + another 100# for the weight of your WD hitch. Also check your rear axle load limit as you may already be over but certainly will be very close to its max.
If you have much if any payload remaining {and I sincerely doubt it}, it will quickly disappear as soon as you load the Tahoe.
Now consider your Tahoe, {the dog... no pun intended}, attached to the 35' tail. I think you can see where I am going with this analogy. Yep, on anything but a straight relatively level road with little or no wind the tail will be wagging the dog.... big time.
I'd recommend more truck or less trailer.
As always.... Opinions and YMMV.
:C
