legerh's avatar
legerh
Towing Capacity of Ford Explorer
We are upgrading from a tent trailer to either a Hybrid or Travel Trailer. We have a 2013 Ford Explorer with the towing package - 5000 lb towing max.
I am not sure how to determine the towing capacity as I have had different answers from different sales people. Should I be using Unloaded Vehicle Weight and then try to estimate how much we will carrying in the trailer? Does the UVW include the Dry Hitch weight or does that get added on too?
Finally, I am not sure how to determine the appropriate length to tow safely. We looked at a Salem Cruise Lite 261BHXL with UVW 4537 lb and a cargo carrying capacity of 2897 lb - GVWR is 7434 lb We would not be filling it with water, however, before we arrived at the campsite.
The length is 29'1". I am not sure how to determine the appropriate/maximum length to tow safely either. The salesperson assured us that we could tow this trailer but my gut instinct is that it is too big.
Help!! This is all new and I am not sure how to determine the maximum unloaded vehicle weight or the length that we could safely tow.
  • The most important thing to know is your vehicle's payload capacity and the hitch ratings: Ford Towing Guide The payload capacity is on a sticker on the driver's side door jamb. Subtract from that number the weight of all passengers, cargo, and the tongue weight of the trailer. If you have a remainder, you're good to go as long as the hitch rating is adequate.
    Length makes no difference other than the fact that your Explorer is going to a white-knuckle affair with close to 30' hitched behind it.
