ognend's avatar
ognend
Explorer II
Jan 09, 2021
Towing capacity vs max cargo weight rating
Hello all!
Can someone clarify something for me? If a truck's max gooseneck trailer loaded weight is 15,100 lbs (as per manufacturer towing guide - it is a Ford) - how can the max cargo weight rating be 1792 lbs?
If I understand correctly, the max cargo weight rating is all the weight that can be put into/onto the truck (passengers, their things) PLUS the, for example, weight of the gooseneck pin of the loaded, 15,100 lbs trailer.
Ford's towing guide says: "Cargo Weight Rating shown in chart is maximum allowable, assuming weight of a base vehicle with required camper option content and a 150-lb. passenger at each available seating position".
Does this mean the allowed payload is AFTER 5 passengers? if I removed 3 passengers, does that add 450 lbs to payload capacity (max allowed cargo weight as per Ford)?
In addition, what gooseneck trailer weighs 15,100 lbs (max loaded trailer weight spec as per Ford) but only 1792 on the hitch (as per max allowed cargo weight)? This would imply that only 12% of the loaded trailer weight is on the hitch. Does this sound right?
I know this is not the case for my loaded horse trailer with living quarters (but then horse trailers with living quarters tend to be front heavy).
Am I understanding this right?
Thanks!
  • That truck per door sticker does not have the payload to tow that trailer.
    Now, if you know the actual tare empty wieght of the truck, subtract that from the sum of the gross axle wieght ratings, assuming you can load evenly, that is your max payload you should out on the truck.
    Max payload and trailer do not tyically equal ea other. If you are pulling a ball mount with 10-15%hitch at, you can pull more than a gooseneck/5w setup that need 15-25% he to tow properly. Reality is, one needs a larger gvw/payload truck for a 15k trailer with a bed monut, vs a ball/bumper mount trailer. Something many do not take into account choosing a truck or trailer.
    Then again if you want to discuss federal bridge laws vs warranty ratings, your perfectly legal wieght wise with that combo. You may or may not get ticketed for other requirements.
    Marty
  • rhagfo's avatar
    rhagfo
    Explorer III
    Well typicality goose-neck trailers are flatbeds and you can adjust the load to get the pin weight down.
