68ltd's avatar
68ltd
towing fuel milage
I just returned from the first long trip with my new truck and was disappointed in only getting 10 mpg.
The truck in a 2014 Chevy Silverado double cab with the 4.3 v6.
My trailer is only 17ft and has an empty weight of 2300 lbs. I was the only passenger and was loaded very lightly (empty water tank etc.)
For 3 years I pulled it with a 4 cylinder Chevy Colorado and it got 13 to 15 mpg depending on speed. Even though my truck has a v6 it never lacked for power even in the rocky mountains. I started rving with my parents in 1971 so I know towing mpg is never good, but I expected better than this. It didn't change whether I drove 60 or 68.
Any thoughts?
  • As stated in op the trailer is very small, I pulled it over 20k with a 4 cylinder Chevy Colorado. The current truck is rated to tow 6000 lbs. Power is know problem. I just expected better mpg. I've been towing small trailer with 4 and 6 cylinder trucks since 1990!
  • Sounds normal but is it really a problem? What percentage of your miles are towing vs your other use of the vehicle? If you did a 1000 mile trip at 10 mpg vs 13 mpg the difference would be about $47.00 Not enough to worry about if the vehicle does everything else well.
    As donno said, your axle may be a big part of it. What is the mileage when not towing?
    I had a 1999 Silverado plain Jane truck with a 4.3 and ran the snot out of that thing for 225,000 miles. I did replace the intake gasket and water pump at 160,000 but it was a fantastic engine. It still ran excellent when Obie gave me $3,500 on the cash for clunkers deal.
    I also had a 2013 Silverado 5.3 with a 5,000 Jayco TT that got 10 or 9 at times.
    I now have a 2014 CTD that's doing 22,000 gcw and it gets 10 to 11 but empty at 60 it gets 25
  • ^ baloney. Clearly someone who never drove a 4.3.
    OP- fuel mileage is mostly determined by wind resistance. And no, it won't improve I you get a bigger truck. 10 is not unreasonable.
  • Too much weight, not enough motor. And probably the wrong rear end ratio. You bought yourself a fancy grocery getter with an open bed in the rear instead of a real truck to work with. Can you fix it? Maybe, but IMHO you would be better off trading for a more capable truck.
