Jack1776's avatar
Jack1776
towing hitch for new trailer
Purchasng a used coachman 2021 spirit northern ultra lite 1943Rb. Its about 24 feet weighting about 4900lbs with a hitch weight of 520lbs. Will be towing w/ a 2020 ford F-150 w/ the small eco engine and a tow capacity of 7300lbs. I am 76 years old and looking for hitch that is capable but hopefully easy to hook up. Thank You
  • "weighing about 4900lbs with a hitch weight of 520lbs."
    That's just a spec over 10% and too light IMO. Shoot for 13 to 14% of the loaded weight of the TT.
  • Don’t have one but it seems the lightest and easiest to adjust is the Anderson.
    I have a Husky Centerline TS and it works great but is sometimes noisy and heavy for me. And I’m a young whipper-snapper at 67!
  • Second Chance wrote:
    Those weights are all empty weights - pretty useless numbers and should not be used for determining an appropriate tow vehicle or hitch. The GVWR of that trailer (fully loaded) is 6,500 lbs. which will yield a tongue weight around 780 lbs.
    Rob
    X2!
    Actually 6,500 lbs GVWR has the potential of 975 lbs at 15% of tongue weight when fully loaded..
    780 lbs is only 12% of TW, the max towing stability is achieved when your TW is at 15% of the trailer weight.
    Yes, the recommended TW range is 10% - 15% and 12% is in sort of in the middle, it is better to shoot for 15% than 12%.
    Maxing out your TW to 15% is advisable.
    Granted, most likely you will not get to the GVWR but one should always plan for it just in case you end up getting close to the GVWR..
  • Those weights are all empty weights - pretty useless numbers and should not be used for determining an appropriate tow vehicle or hitch. The GVWR of that trailer (fully loaded) is 6,500 lbs. which will yield a tongue weight around 780 lbs.
    Rob
  • If you're worried about weight the lightest I'm aware of is Andersen.
    https://andersenhitches.com/product/weight-distribution-hitch/
  • Get a Hensley Arrow or a Pro-Pride. Each cost a few $$. I purchased mine used on eBay. IMO it should be against the law to sell a TT without one of these hitches. ... :B .... :B.
    NO MORE TAIL SWAY. I once had a wheel come off my TT while driving 75 MPH and did not know it until a car passed me and wave me down to pull over. The Arrow probably saved my life.
    Search the posting to see other comments. I am 85 and not problem hooking up. A few tricks to learn. Most important is do NOT turn you steering wheel the last 5 feet when you back up to the hitch.
  • Equal-i-zer brand is a good one. A 10,000 gross/1000 hitch weight rated one will do just fine for your weight of trailer. Like any hitch it is on the heavy side. I ordered one of the hitch gripper handles to use to carry mine and it does help. I think the Equal-i-zer is easy to hook up compared to some others with the chains type.
