Bedlam
Feb 22, 2018Moderator
soren wrote:Cummins12V98 wrote:
From a pure safety standpoint I would never consider towing 12K with a gasser down 6-14% grades. What a pleasure it is to go down these grades without touching the brakes and knowing you have cool brakes if needed.
Now as mentioned ya may want to look at trucks from the last 5 model years. IMHO the RAM trucks have proven to be very dependable with their electronics and drivetrains. Also they have the gold standard Bosch CP3 injection pump. GM and Ford used the CP4, GM gave up on that with so many warranty claims they now use the Denso pump.
I can't imagine how many tens(hundreds?) of thousands of us are driving large gas motorhomes, on top of the Ford F53 chassis, with hill descent control built into the transmission. I have made many trips in and out of Yellowstone, from Eastern WY. in my ten year old 21K gasser. Doesn't matter how steep the grande is, or how long. My gasser gets to the bottom with brakes that are stone cold. With the right drivetrain, and skill set, descending the biggest mountains in North America is a total non-event. That said, I'm still amazed by all the concern for "screaming gas engines". It's not 1975 anymore. They are made to perform for hundreds of thousands of miles, with the RPMS up in the power band, when needed. My v-10 regularly cracks mid-5K when pulling out from a stop , or attacking a grade. The motor is maintained with an OEM filter and oil, every 5k and has 80K on it. Not much compared to a hot shot delivery driver, running a one ton diesel for a living, but quite a bit for a motorhome of this age. It doesn't need any oil between changes.
I have a different view of this as a prior diesel motorhome, and pickup owner. In the OP's position, I would find a 3-4 YO gas pickup and take advantage of the soft resale numbers on gassers. Having spent the last three years,putting 50K miles on a gas V-10, moving 25K pounds on a regular basis, I know that a diesel motor is a better option to do the job, but far from a requirement.
The V-10 is only available in chassis cabs, cut aways and stripped chassis. Smaller platforms are not offered with this engine.
I looked at getting a gasser rather than diesel to avoid the additional cost and complexity, but realized I was too borderline with all the mountain driving I do at my current 18-26K GCW. Due to the lower fuel mileage, it would also require more frequent stops or a larger gasoline tank.
44,064 PostsLatest Activity: Apr 11, 2026
