Meechy's avatar
Meechy
Towing Newbie
Hey All,
I'm brand new to this wonderful world and want to thank you all for all that you contribute to this site. I've learned so much and am so eager to continue to learn.
Now we just purchased a 2015 Coachmen Viking 17RD.
We are planning to do some cross country traveling and are looking for a Tow Vehicle.
What I'm wondering is if we need a V8 for our cross country trip in a 3705lbs CVWR trailer. We were looking at a V6 like a Pathfinder or something with a 6,000lbs tow capacity. After reading some posts I'm starting to wonder if we need a V8 to be on the safe side. We plan on getting a weight distribution hitch with sway and brake controls.
I appreciate your opinions and am sure the will help in our decision.
Thank you
  • Depends on your route, and what you will be using the tow vehicle for when it's not camping season. You will probably be happier towing over the mountains with a larger engine, but if the tow vehicle is to be your regular daily driver, you'll of course want to keep its expense and usefulness under consideration as well. Sometimes it's a compromise. Good luck with your decision, and welcome!
  • I justed looked at that unit online and see it has a dry weight of approx. 2830lbs. So yes, anything with a 6000 lb towing capacity should be more than fine. Loaded to the max your tongue weight would be under 400lbs, and the unit being under 20 feet, you would be fine with a six cylinder you described.
    Check the CCC of any vehicle you look at (yellow sticker on driver door frame).
    Good luck!
