jaycocamprs
Mar 07, 2022Explorer
wowens79 wrote:
By the time you add the heavy tow and payload to a 150, it is as much as a F250. The 250 with the bigger brakes, axles, stiffer frame, and pretty much heavier duty everything will be a much better option. The new 7.3l gas engine is a really good choice for that weight.
This is so true. It's not that you can't get a F-150 that will do the job, you can. But any F-250 will, and likely do it better.
