RinconVTR wrote:
MFOX wrote:
We are also looking at a KZ Frontier 2505 that the GVWR is at 7000 lbs.
There's nothing but******for replies in this thread so far.
NO ONE pointed out you stated the trailer is 7000lbs GROSS, meaning it will likely NEVER come near that number unless you carelessly overload it.
Dude, sorry, but you are so wrong... We just happen to have a KZ TT with a GVWR of 7,000 lbs. Weighs 6800 lbs loaded for camping with some ordinary/basic stuff loaded into it. It would be very easy to overload. Travel with just one holding tank full and it would be over the GVWR. Pack more stuff into it for a long road trip and it could easily be overloaded. Not an uncommon situation. Not only this, our KZ TT has a tongue weight of almost 15% of the GVW - nearly 1,000 lbs. and approaching double the factory dry number. Don't give someone advice if you don't know what you are talking about. Too much of that going on as it is.
Problem when shopping for a new TT, you can't just run them all to a scale. Using the GVWR would be the smart thing to do. Never use factory listed dry weights for decision making for a TV.
To the OP, towing near the max. tow capacity of a TV is not a good idea. You'll be under-powered and overstress the drivetrain and you'll be very slooow. On steeper hills you'll be down to around 30mph flat out and you'll find it hard to maintain speed when it's windy & gusty. BTDT and never again... You really need to know what your
actual payload capacity and tongue weight is. For an SUV, the GCWR could be a factor too. You may need a TV capable of 1,000 of TW payload for that KZ. I can't see use anything less than a 1/2 ton (or equivalent), and not just any old 1/2 ton either. There are a few choices in bigger SUVs that'd work, like a Suburban 2500 for ex..
When looking at a TV's payload capacity, the factory curb wt. only includes for a 145-150 lb driver and full tank of fuel. Kids, pets, the DW, groceries and camping gear can easily add 400-500 lbs of payload. Throw some firewood and a generator in the back and you'll be more. For that KZ TT, you *could* require a TV with an actual payload capacity of around 1500 lbs. You'd also be wise to weigh your TV and subtract that from the GVWR on the door jamb sticker as in some cases, the actual payload capacity can be a lot less, particularly if your vehicle has a bunch of heavy factory options. If you are going to push the limits of your TV, you really ought to know the actual numbers.
