CKNSLS wrote:
gmw photos wrote:
I think the point of the whole argument regarding the trailer gross weight rating vs what it's advertised dry weight is....and all the yada, yada that surrounds the discussion is this: you need to know what the trailer really weighs, as you would use it, ready to go camp.
For instance, my trailer has a GVWR of over 6000 pounds, but in reality, it weighs just under 4000 pounds when I pull out of the driveway. So it's good to know real numbers, and there is no substitute to rolling it onto the scales to find out the truth.
A lot of beginners have no concept of PAYLOAD and they don't even know where that little yellow and white sticker is located. That is where the problem of towing weights come in. Generally with a half ton truck with a standard towing package you will not be able to tow the full manufacturer's weight rating because you will EXCEED PAYLOAD FIRST. So many first timers have no concept of this equation.
Thanks for bringing payload into the discussion. Saying my TV can tow xxxx pounds really doesn't mean squat. As I have read again and again - and quoted above, payload is usualy exceeded well before you reach towing limits. To the OP: Payload includes the weight of all passengers, cargo, and a full tank of gas. It also includes the weight of the hitch(the thing that plugs into the receiver)and the tounge weight of the TT which includes front mounted items such as a batterty and propane tanks. All this weight cannot exceed the Gross Vechile Weight of your TV.
Towing capacity boils down to the estimated weight the TV can tow utilizing the equipment it has - engine, suspension, transmission, gear ratio, etc. This number is supplied by the manufacturer and is usually inflated because they don't use real life scenarios to determine it.
One more thing to look at if buying a used TV is the tires. Are they OEM tires or are they just something slapped on by the prevvious owner in order to save a few bucks. Properly inflated OEM tires are part of the calculation that determines gross vechile weight.
Actually another thing to consider is that in the future, you may want to upgrade the TT. Buying more TV than you need at present - like a 3/4 or one ton TV will allow you to do so, and it does not necesarily need to have a diesel engine or dual rear wheels - depends on what you think the future may hold.
Here is a
Cat Scale Locater link that may be of help.
Good luck and let us know what you decided to do.
