machunt
Apr 30, 2013Explorer
towing rpm
I have a 2004 dodge CTD with 3.73 rear end when i tow my 5ver in tow haul mode my rpm,s are runnibf 2500 rpm at 60 62 mph, sound about right? truck is a 4speed auto
boogie_4wheel wrote:With reguard to the t/h mode, if I push the button I run the ops' rpm. I put my '04.5 in D and go. I very seldom push the button. I generally run 1800 rpm on the interstate with very little down shifting and 55 mph on other roads.
If this is an early 04, try running with the T/H off. This will allow it to drop into 4th and would probably net you some fuel economy. Save T/H (OD lockout) for the hills.
The 04.5+ T/H allowed 4th gear operation, but 04 and older was an OD lockout feature. I don't know the specs on your FW but would at least try to pull it in OD.
.jpg)
4x4ord wrote:
Your automatic has 2 choices it could run in 3rd gear at 2500 or 4th gear at 1725 rpm. At 1725 The Cummins should be capable of making around 175 hp which should be lots of power to tow most 5th wheels down a level road so it surprises me that it chooses to run in 3rd over 4th. I would still trust that the computer know what gear to select. By the time my Ford is pulling hard enough to get the revs up to 2500 rpm I am getting around 5 mpg.
