?1.I’m considering purchasing a small lot where I can pull up w/ a truck camper and stay at like a campsite not sure if the local residents allow even a land owner w/ a power pole to squat for a week at a time. were talking underdeveloped wet lands in Perdido bay area this area is very ritzie.
?2.what type truck is required to firstly tow and stop my 4K LB vessel w/ a decent camper.
?3. I like the wetlands idea so the truck would probably be all wheel drive or 4 wheel drive probably gasoline engine not liking the noise of desil or extra cost of fuel.
1-Before buying a lot the realtor will know what and if there are any restrictions..
2-A 4k vessel is equivalent to a 22-24ft travel trailer both in weight and tongue weight..So with a TC on also I would think a 1-ton/3500 series would be best, especially a DRW..
3-Same as 2..
As to the death wabble,I have had it happen twice,both with Dodge chassis older Class C motorhomes..The problem was worn rotors on both..You should/would not get that with a newer rig..The death wabble is caused by worn out front end parts and equipment..
