BenK
Aug 11, 2021Explorer
Confusing using marketing nomenclature…F150 has over a dozen different ones…so which one ?
Best to use their actual ratings. Like GVWR, FGAWR, RGAWR.
Look at the RGAWR and get the one with the largest rating. There is a reason why the bigger TV’s will have RGAWR’s starting at 6,000 lbs.
IdaD mentioned the F150HD and that one will have the highest RGAWR
As for the trailer’s tongue weight vs your possible TV purchase…look up it’s advertised weight and tongue rating. That is normally an empty trailer and will provide for guesstimating of the actual tongue weight
What you are looking for is the tongue percentage weight.
Then take the trailers GVWR to figure out it’s tongue weight to figure out if that TV will be rated for that
Not a sure fire, as depending on the trailer, some will have their loaded tongue weight something other than the brochure tongue percentage.
If you are stuck on purchasing this TV and trailer, then take the trailer brochure listed weight & tongue, which is an empty trailer with no optional equipment like propane tanks, spare, battery, etc.
Then subtract that from the TV’s GCWR and that is the maximum your TV can weigh and still meet GCWR.
I have no skin in your game and am just providing information for the OP to make a good decision.
