Lantley
Oct 04, 2013Nomad
06Fargo wrote:dodge guy wrote:RCMAN46 wrote:
A 4.30 axle will not give you more horsepower! Even with the 4.30 you will still have to wind your engine into 5000 rpm territory as you do with the 3.73 to pull the same hill with the same trailer at the same speed.
Um.......no!
All other factors the same a 4.30 ratio truck will out pull a 3.73 ratio truck on hills and high headwinds.
I guess the 1st factor to consider is will it pull $2500.00 better on a truck with a 6 speed transmission?
