- Md_06UnltdExplorer
mrkoje wrote:
http://www.jeep.com/en/jeep_capabilities/towing/#GrandCherokeeTab,http://www.jeep.com/en/jeep_capabilities/towing/#GrandCherokeeTab,
Thanks for the link....I got a new t-shirt! - librty02ExplorerI have a grand cherokee what year is yours and what kinda trailer weight are you looking at. I will give you what I think about how they tow
- go_wildExplorerHi, I have an 18ft hybrid (3500 lbs)and for the first two years I pulled it with a 1997 Grand Cherokee with the 5.2L V8 and tow package (7200 lb tow capacity). That vehicle had 220HP and did OK pulling the trailer. Acceleration was slow and headwinds/sidewinds really impacted performance (MPG suffered, difficult to maintain 55 MPH sometimes) but with the Equal-i-zer WDH I never felt out of control; it always felt solid and stable. I thought it was a good pairing, but the Jeep lacked overall power. So as you can guess, I would not recommend a Grand Cherokee with the smaller I6/V6 for towing a 23ft hybrid.
- rexlionExplorerIn other words, Rangerbob, the answer to your question is definitely yes, definitely no, and maybe. Pretty typical for around here! :D
- Chuck_SExplorerThe answer is No. Sure you can get it home. Sure you can pull it. But you will be very unhappy and you may damage the truck.
5000 pounds is the maximum towing capacity, not a planning number. It assumes the truck is empty other than a 150 pound driver. Add your family, dogs, and camping gear and that rating is probably much closer to 4000 pounds.
I know of no 23' hybrids that weigh less than 5000 pounds loaded. Their empty weight doesn't count.
There are a zillion towing "rules" with some requiring a degree in advanced mathematics. I have two very simple rules: The 1000 Pound Rule and the One Ton Rule. Yeah, I made 'em up but the results are as good as the fancy formulas. Simply stated I want at least 1000 pounds more maximum towing capacity than the trailer weighs fully loaded. And for peace of mind I really want an extra ton! You won't be happy towing a 5000 pound trailer with a 6000 pound max-rated truck. You won't hurt it, but you won't like it.
I pulled my 5000 pound Roo 23SS with my 5500 pound rated V6 Explorer for two seasons. I flogged the poor beast up every hill and into the wind. The engine and transmission were never happy. I replaced the Explorer with a V8 Expedition with the HD Tow option, 9000 pounds max towing. Happy towing for this camper. 6000 pounds standard, 9000 pounds with HD Tow. For a 5000 pound trailer. HD Towing package on my Expedition cost me $350 when factory installed.
We all tend to get defensive with someone criticizes our choice of anything. ;) If you decide to ignore the laws of physics and pull a 23-footer with a country club SUV at least get a transmission temperature gauge and monitor it closely.
-- Chuck - ChooChooMan74ExplorerIt should tow it but may be a bit of a struggle. Weight is not the issue. It is the wind resistance of a giant sail behind you. The more streamline of a trailer you can find, the better you'll be.
- chevyman2ExplorerYes, years and gears makes all the diff. Now think of this. WILL it tow your HTT? I will bet that it will, and probably all day long on flatgrounds. Should it tow that HTT? Probably not. But, I towed my 32' TT with my 4.7 powered Jeep GC. It did a fine job. HOWEVER, I always knew it was there. It sure does tow my PUP lots better.
- mrkojeExplorerhttp://www.jeep.com/en/jeep_capabilities/towing/#GrandCherokeeTab,http://www.jeep.com/en/jeep_capabilities/towing/#GrandCherokeeTab,
- bikendanExploreri have a 23' HTT and there's no way i'd tow it with a 6 cyl. engine, unless it was the F-150 Ecoboost or the newer Dodge Penstar v-6 engine.
you need to post what HTT you're looking to tow and provide more info on the Jeep, that just it having a 6 cyl. engine.
like, what year GC, what rear end ratio, size of engine, factory tow package or not. - rexlionExplorerWhat year is your GC? The big thing to watch out for is probably the hitch weight. If your GC has 5000 lb tow rating, the hitch rating is probably 500. I had a 2005 Rockwood 23 footer, and althoughI never weighed the tongue (I should have) it was heavy enough with full tanks to bend the left rear spring on my Mountaineer (6000/600 rating). It has a lot to do with where your water tanks are; the Rockwood's fresh tank was right up front, and added to 2 propane tanks, battery, and stuff in overheads above the front bed, it really added up. The overall trailer weight was fine at about 4K loaded, but heavy on the tongue.
The newer GC in particular should handle quite well IMO, but the wheelbase is short enough to make anti-sway desirable with a trailer of that size. Equalizer, Reese Dual Cam, Anderson No-Sway are some hitches to consider.
44,054 PostsLatest Activity: Dec 18, 2025
