DoneItAll
Nov 18, 2013Explorer
Towing
My F450 is equipped with a stock class V hitch. Am I correct in that I would only need a TorkLift SuperTruss Extension Bar to be able to tow?
Thanks,
John
Thanks,
John
Reddog1 wrote:
I have been flat towing my Samurai for thousands of miles, since 2004. I have the OEM hitch on my truck, and about a 4-1/2 foot home made 2"x 3/16" wall extension. I use 5/16" chains or tubing from each side of the extension to the Hitch. Considering there is zero tongue weight,nothing heavier is required.
kerry4951 wrote:
Why don't you look at the Reese 2 1/2" extensions. They offer one in 41"-48" length. I use one with stabilizing chains for my ATV trailer and it works great. I did remove my factory OEM hitch and replaced it with a Reese Titan hitch. There was a big difference in how much better the Reese was compared to the factory GM hitch.
Mello Mike wrote:
I can see the need for stabilizing chains for long hitch extensions greater than 40" but why would you need them for something much shorter? My extension is 18" long and I've run into zero problems without them.
