valhalla360 wrote:
Heymon wrote:
valhalla360 wrote:
I'd have to dig it up but unless your state makes an exception to the uniform vehicle code, you are required to hold a steady speed when someone is merging in.
As I've said in previous posts, if you can move to the left, that's fine and probably better (though not a requirment) BUT that wasn't available to the OP because there was a semi in that lane and while it's nice to say you would never get in that position, sooner or later it will happen.
Also, if you are going to hang in the middle lane, make sure you are keeping up with the faster traffic. Yeah, you will burn some extra gas but if you run a 55 in the middle lane and they want to go 70 you are creating a new safety problem.
You can dig if you want, but I do not know of any rule that "requires" you to maintain a speed in this case. The vehicle that is already on the freeway has the right of way over the vehicle trying to get onto the freeway, that much is true. But I defy any officer or anyone else to cite someone who slows down to allow a person to merge ahead of them. Stubbornly keeping a speed when it is all too obvious that someone will be hitting you can actually end up having you at least partially at fault for an accident for failing to take available evasive action.
As I said, states can override sections of the code but most follow it.
Worst case senario if there is an accident and you were clearly not holding a steady speed, you can still be held accountable for intentionally blocking the merging vehicle at that point it won't matter.
Yep, it`s called "failure to reduce speed to avoid an accident" it can be written on the merging vehicle as well as the vehicle on the hwy!
It is the job of the person behind the wheel to keep things safe, for both you and the people around you. If this means slowing down, speeding up or changing lanes then that`s what you have to do. I believe that was covered in drivers ed!
