Graycat
Sep 22, 2015Explorer
Oasisbob wrote:
What trailer manufacturer lays claim to this? Sadly supports what RV quality has come to.
CruiserRV. It's a Fun Finder. And yes, doing the few mods we have done so far, the construction is pitiful.
GMandJM wrote:
If you make a larger support for your mattress, will you still be able to walk around the sides of the bed?
And, if so, why not just build a new, right-sized flip-up part with side supports and replace the original section? You could likely use the same hinges.
Front-facing doors on the underbed storage area would be great. Drawers would be even better, imho.
Good luck.
Yes, we won't be changing anything except adding support inside the existing base and a larger piece of plywood, and yes, using the same hinges.
I'm not sure why others have nailed support pieces to the plywood instead of inside the base. It may be because it is easier, since that could be done outside the trailer. Or maybe there's another reason I'm not aware of.
44,068 PostsLatest Activity: Jun 21, 2026
