a_flyfisher's avatar
a_flyfisher
Trailer Hitch Questions
I plan on towing a relatively small trailer behind my truck after I buy a new Northern Lite truck camper this spring.
Mostly, I'd have my 16' drift boat, which probably weighs under 1,000#' for the boat and trailer combined, but from time to time I'd have my Polaris Ranger side by side, which I tow on a heavier 12' Triton trailer, and together they probably weigh closer to 2,500#, or maybe a bit more. The tongue weights on my boat trailer is probably around 100#', and around 250# on my other trailer, more or less.
My 2011 Ford Super Duty dually truck has Ford's OEM 2 1/2" receiver.
My question is would I have any trouble towing either of these trailers if I simply get a 24" - 36"' receiver extension for my Ford OEM receiver? I'd hate to think of needing to buy something like a Torklift Super Truss hitch system, if I can safely get by with something like a Titan receiver extension (rated for pin weights of 450# or more, depending on the receiver extension length) which costs around $200.00.
John
  • You will find some answers in my topic about 3" receiver.
    Bare in mind that 450lb on 36" stinger can add 900 lb on your rear axle, so depends on your camper weight, that most likely will be your limit.
