maxwell11
Apr 22, 2015Explorer
Trailer hub temp question
figured you guys would know if anyone would.
I have one of those red dot temperature guns
when traveling, you pull in for a rest break, pull out your red dot temperature gun and check the trailer hubs.
question: what is an acceptable heat range for the hubs??????
I am assuming they all should be fairly close together in temp range.
thanks for your reply.
27 ft tow behind lite trailer. standard unit, 15" tires, 2 years old.
hubs have those pop off covers with grease buddies, where grease zerk in right at the end of the hub, I normally give them 3 shots of grease, two or three times per season.??????
