dodge_guy
Apr 10, 2014Explorer II
maxwell11 wrote:
This months Trailer Life Magazine had a write up on the 5.9 Cummins engine, the write up covered at least 6 or 7 pages.
As I read the article all 5.9 Cummins engine block coolant plugs rust out. The article did not place our truck engines in a very good light.
I had the coolant changed in my 2005 dodge diesel truck at 5 year intervals with Dodge approved antifreeze and distilled water.
So far, I have had no problems with the cooling system. However, after reading the article I will keep a bit closer eye on the motor block freeze plugs.
Have any of you guys had problems with the freeze plugs rusting out and leaking coolant????
Only on the unmaintained trucks. if you maintain your vehicle it should give no issues!
