maxwell11ExplorerApr 10, 2014Trailer Life Article - 5.9 Cummins engineThis months Trailer Life Magazine had a write up on the 5.9 Cummins engine, the write up covered at least 6 or 7 pages. As I read the article all 5.9 Cummins engine block coolant plugs rust out. T...Show More
cmarqExplorerApr 11, 2014Antifreeze has a rust inhibit change at the recommended intervals and you will not have a problem.
Related ContentComical EV articleCummins Hit with 1.7Billion for Emissions Defeat Devices6.7L Cummins VS 6.7L Cummins HOTravel TrailerRam Cummins/Aisin Failures
