john_bet
May 11, 2014Explorer II
Cummins12V98 wrote:No need to talk to after market shops. I just go up the road 20 miles to OEM shop along US-31 with the big "C" on the sign. Or talk to people I know in the big "C" Tech Center. Have a good day.john&bet wrote:Cummins12V98 wrote:Cummins12v98, I call that statement bull. '04.5 with 163k and still all original injectors and lift pump. Pulling out in 2 weeks for a 7week,5k trip and I have no worries. JMEFishOnOne wrote:ib516 wrote:
OK Troy, whatever you say. We all know you take every opportunity to say the Cummins diesel is junk. That's fine. Pretty sure that opinion is contrary to most people's opinions and experiences.
But hey, we are all allowed to have our opinions. :)
Carry on...:B
OK Ian... I've owned 05 Dodge and my cousin wrenches on them. Injectors on these common rails fail more than your internet buddies report. :W
People with the 03-07 5.9 Cummins should be running as small of a micron fuel filter as possible if they want to make it past 150K.
Say bull all you want but you talk to Dynomite Diesel or any Bosch injector shop and they will tell you the same.
Like everything there are variables. So you won't run a 4 micron filter if it will help your injectors run longer?
There are several things one can help prevent or fix on a Cummins if they so choose.
1. replace starter contacts before it won't disengage and burn up wiring
2. replace lift pump on 98-02 24 valve before the lift pump takes out the injection pump.
3. Tab killer dowel pin before it comes out and damages the timing case.
There are several more but bury your head and roll the dice. I don't I fix things before they become a problem.
