ROBERTSUNRUS
Jun 02, 2016Explorer
stevenicol wrote:
...when you check the torque of your trailer lugs, do you loosen them first, or just test the torque tightness?
:) Hi, there is no reason to loosen your lug nuts unless you need to remove a wheel. Once removed for any reason, then hand torque the lug nuts to specs, and one more time while on the road. Never lube the threads.
