stevenicol's avatar
stevenicol
Trailer lug torquing
...when you check the torque of your trailer lugs, do you loosen them first, or just test the torque tightness?
  • I use anti seize and torque to the lubricated value. You do not want to loosen or you lose the value of having re-torqued.
    When wheels are removed and replaced you do an initial torque and then fifty or so miles down the road they are re-torqued.
    If you think that they might be OVER torqued.,..then yes...loosen and re-torque.
