- huskym1025ExplorerI used the clear version of Flex seal to repair a leak around my antenna. The trick is to spray several thin coats, allowing the coats to dry between sprays. We had rain and snow here and so far no leaks.
- dahkotaExplorerThe flex seal did what I needed it to do. We now have more dicor and are planning to reseal the problem area this week. Considering we had another 6 hours of heavy rains and no leaks after applying a thin layer of flex seal, I believe it served its purpose as a quick, but temporary remedy.
- samhain7ExplorerI think most agree that to properly seal a leak, it is all about preparation.
I would hate to see what it takes to remove the Flexseal (to prepare for a proper repair) from your roof should it fail... - westendExplorer
dahkota wrote:
We just had torrential rains down here in Florida. One of our lights started leaking! There was a gap somewhere on the roof water was getting in. Since we had recently had a satellite dish removed, we figured it must be there. During a break in the rains, I went up on the roof and sprayed the **** out of the places where the satellite dish had been mounted (dicor was used when it was done). I used the only thing I had since I only had about a fifteen minute break - Flex Seal. No more leak! Yes, it actually worked, keeping the 2" an hour rain out of my RV.
We do plan to go back on the roof to add more dicor but, for a quick fix, Flex Seal worked and I am glad we carry it.
I'd caution you that Flexseal is soluble in water and might not fix your leak permanently. Also, the place where you see water exit in the interior has more to do with the low point where water can travel than the entrance point in the exterior. You may have located the leak entrance at the satellite dish mounting location and may have not. I'd suggest you perform a pressure leak test to identify and seal any leak entrances found. There are a number of different products used for different roof materials. If you have an EPDM roof, Dicor self-leveling has had good results for a lot of RV users.
Good luck with the leak prevention. - dahkotaExplorerWe just had torrential rains down here in Florida. One of our lights started leaking! There was a gap somewhere on the roof water was getting in. Since we had recently had a satellite dish removed, we figured it must be there. During a break in the rains, I went up on the roof and sprayed the **** out of the places where the satellite dish had been mounted (dicor was used when it was done). I used the only thing I had since I only had about a fifteen minute break - Flex Seal. No more leak! Yes, it actually worked, keeping the 2" an hour rain out of my RV.
We do plan to go back on the roof to add more dicor but, for a quick fix, Flex Seal worked and I am glad we carry it. - DutchmenSportExplorerWell, I suppose if you want to float your camper upside down in that lake, you can sure try! But as for me, I'd never use it. I'd stick with a known product for rubber roofs that's been time tested and proven. I have no desire to flip my camper over and float it! :)
- downtheroadExplorerFlex Seal....no
ProFlex or Dicor self leveling...yes
Eternabond Tape....yes - gboppExplorer
evanvalk wrote:
Can any body tell me the new Flex Seal can be used to touch up on rubber roof? Thanks.
Don't screw around trying to touch it up. Fix it right and use the correct sealant. And don't put it off, do it ASAP
You don't want a major leak. Trust me...... - RVcircusExplorer II
The infomercial spray? I haven't used it for anything, but I wouldn't be the guinea pig to try it on a RV roof. There are too many EPDM specific products available for me to mess with it. - newman_fulltimeExplorer IIno
44,027 PostsLatest Activity: Mar 05, 2025
