Jack1776 wrote:
I bought a 2020 gulfstream vintage crusier single axle and towing it with my 2021 Ford 150. My queston is: Is it practical to upgrade the trailer suspension for a smoother ride and/or sway? and if so, what would someone recommend?
Thanks...Vincent
Vincent, so now you have had all the ideas one can consume. I will simply say, your trailer will be fine. It is important to look at the tires though. Check the Load Range against the weight of the trailer and air them up as needed. If the load range is just slightly above the weigh of the trailer air the tires to the max.
Load the trailer avoiding putting heavy items at the back. Better to have more weight on the tongue.
BUT...get a good WD hitch with built in sway control and get it dialed in as per manufacturer's recommendations. Trailer sway is something to be avoided.
