chops1sc's avatar
chops1sc
Explorer II
Jul 13, 2015
Tranny temps: how hot is too hot?
I recently got a 5th wheel camper that I will be towing with my 2011 Silverado 1500 LTZ. It has the HD trailering and HD cooling packages (RPO codes K5L and Z82). What would you consider to be high transmission temperature? I can monitor the temp. from the info panel on the dash. The short trip bringing the camper home (10 miles, city, flat with one hill) going 40-45 avg it got no higher than 183F. What temps would I see on the highway going 55-60 tops?
  • When I first got my 07 tahoe, the temps during the first pull (short trip, flat lands) spiked up to 200. I then added the additional factory cooler (which I am guessing you have already) and the temps now stay around 190. Grade, outside temp and humidity, all have an effect on this. I think the highest I have seen is 205, during a climb, or during a high temp high humidity situation. This also occurred directly following a slight increase in engine temp, before it fell back within normal range.
    I think your temps are fine. When I see 200 I start paying attention, just to be sure it comes back down, which it always does.
  • In an '09 Silverado C1500 (with tow package, tranny cooler) that I use to pull the trailer in my signature, I'd routinely see 180s and 190s. If coming off highway and to a quick stop (lack of airflow over radiators), I'd see it spike to 205 to 208, before starting to come back down.
    Discussions on this topic seem to indicate we are okay with very short spikes to 220 or 225. As temps rise, life of the transmission fluid is shortened. There are tables with the temps / miles flowing around on the Internet.
    Hope this helps.
