captnjack wrote:
marcsbigfoot20b27 wrote:
Yep, its not just about the fluid.......its also how much heat the seals can handle. One seal failure can mean totally disabled trans.
I worked at a transmission shop for 4 years (23 years ago) Seen lots of burned up units, some with wasted seals and clutch packs where the glue that holds the fiber to the steel was gone.
Anything over 225 for more than 5 minutes and I would pull over or add a bigger cooler. It doesn't matter if you have full synthetic that can handle 350 degrees if the seals melt.
My truck stock would get up to 210 going up the rim in AZ. Added a way bigger cooler and now it only gets to 160 max ever.
Do you think seal technology has stood still for 30 or 40 years? Just like fluid and everything else, the technology has increased immensely.
Mark; where are you at? Time to straighten some of these people out. :B Your phone is ringing!!
Well I am a sucker for information. Please do show some evidence of how hot is safe for regular and synthetic fluids and the seals in the transmissions. I would love to know the real answer.
Remember that not all of us tow with a 2015, some of us are still old school ~1995-2005
I posted earlier about my 2002 Chevy. 225 for five minutes is nowhere near to being a problem. From the owner's manual. That's good enough for me. Although 225 is around the number I look to stay under. Can't always hit that five minute mark though. I wait for top of hill, then pull over to cool down.
Yep, owners manual kinda answers the problem. Seems like 255* is the number I remember.
If 200* is 'hot,' I'm in trouble. My F150 is at 195-200* all the time (once it has time to warm up, of course)! Even in sub-freezing winter temps. Of course, towing, it stays in the same range, maybe creeping up to 205 or 210* on an extended climb.
