freddmcExplorerJan 29, 2014Trans running hot on 2005Ram 3500 AutoWe tow a horse trailer with our 2005 Ram 3500 dually auto. When towing in the mountains the trans temp will get up to 230 deg. as this year does not have the abililty to lock out the overdrive(both th...Show More
Cummins12V98Explorer IIIJan 30, 2014Run 3rd gear when climbing. RPM's higher is better with the 48 trans if you are towing very heavy.
Related ContentHot Running Trans Temp - Ideas?Trans coolersSynthetic Trans Fluidtrans upgradeTrans mission
