falconbrother's avatar
falconbrother
Explorer II
May 07, 2018
Transmission oil coolers and how cool should you go.
There has been some discussion here about adding a transmission oil cooler, or supplemental oil cooler, and the possibility of too much cooling. Here's a link to the etrailer transmission oil cooler FAQ that says, except in extreme cold climates you cannot over-cool your transmission. And, even then it just requires a couple of minutes of warm up time before driving. My guess is North Carolina never meets the qualifications for extreme cold.
https://www.etrailer.com/faq-about-engine-transmission-coolers.aspx#highestcapacity
I had purchased a smaller transmission cooler that I was going to use to supplement my factory tow package cooler. I had about decided not to install it. Based on this data from etrailer I went ahead and installed it this last weekend.
