Retired_Enjoy_L's avatar
May 15, 2022
Travel Trailer Towing Recommendations
We just purchased our first travel trailer. We are looking at purchasing a new tow vehicle. Would like recommendations on what tow vehicle is best what to avoid. We will be towing a bunkhouse GVWR is 7,500 lbs.
TIA for your recommendations.
  • We were thinking of a Chevy Tahoe, GMC Yukon or Toyota Sequoia, rather than a truck. Thoughts on that for towing?
  • bgum wrote:
    Chevy 1500
    Ford F150
    You should get the trailering package.
    You will be a little heavy for the lighter trucks such as Tacoma etc.
    Ford
    Ram
    GMC
    Trucks either 1/2 ton (F150/1500), 3/4 or 1 ton from the three American manufacturers. A HD truck lets you move up to a heavier TT later without buying a new truck. With tow packages for the 1/2 ton trucks. Avoid other brand pickups (like Toyota) which are not suited for towing. Try all three trucks brands out, you will like one more than the others probably.
    Get a good towing hitch, a weight distributing hitch (WDH)
    When towing keep your speed down to 55-62 mph, mostly stick to the right hand lane on highways and just let people pass you.
    Your fuel mileage with be optimal in that range. Expect mpg in the 8 to 12 mpg range. And towing stability is much better and safer in that speed range.
  • OP, tow vehicles to avoid?
    Since you literally provide no other parameters for consideration to your very open ended question…avoid these….
    Anything mid size.
    Any smaller less capable full size suvs.
    Any half tons that are base model drivetrains.
    No go karts
    Definitely no motorcycles
    Compact cars and mid size cars are out of the question.
    No minivans
    That should aboot cover it!
    Next caller please…
  • bgum wrote:
    Chevy 1500
    Ford F150
    Lol, 5 pages in the TT forum with an owner scared of his own shadow and a buncha folks telling him how bad it will be with his capable half ton and the same weight trailer…..
    Fwiw, any 7500lb trailer is absolutely half ton towable and I agree with you.
    Just struck me funny is all!
  • Tongue weight will need to be about 1000 pounds. Many half tons won’t be rated for that weight. My 1500’s max is 970 pounds. Avoid half tons.
  • Chevy 1500
    Ford F150
