valhalla360 wrote:
Specs say 4400lb axles...even 3500lb should be fine with a GVWR of 7800 (should have around 1000lb on the hitch).
Real question is why on earth would you drive 15hr to buy? By the time you add gas, lodging, food, wear and tear on the truck and not having a local dealer, I would want a heck of a deal (as in a good $10k off compared to local).
I also don't get if it was clearly sagging, why the dealer or you weren't able to find out why.
If you can’t drive 30 hours ( not 15) for under $1000, you’re doing it totally wrong.
But thanks for the lack of useful input.
