skidsteerpilotExplorerFeb 10, 2018Tread Depth/Wear Marks/Tire ReplacementDo you run tires to wear marks before replacing? Currently running 275 R70 18 Firestone Transforce HT on Dodge 3500 SRW w/Northern Light 10-2. Tires are approx half way to wear marks compared to n...Show More
donn0128Explorer IIFeb 10, 2018Replace at minimum at the wear bars. But if they get the least bit squirrly in the wet dump em.
Related ContentReplacement Lights for TTWierd Marks Appearing On TiresTire manufacture date markingReplace insulation inside heater column.Tire Rubber Marks On Fender
