- dodge_guyExplorer II
Cummins12V98 wrote:
dodge guy wrote:
It doesn't really matter unless the tire is asymmetrical or directional.
There are 2 ways to look at it. On the outside it's easier to read. But on the inside it protects it from getting ground off from curbs, although that shouldn't be an issue on a trailer.
If you are grinding off the date code that is near the rim and actually indented into the tire you won't have the tires long enough to worry about the date!
I did have them mount my date codes to the outside on my new Motorcycle trailer tires.
You are correct. That should never be an issue, but working on customer cars you would be surprised at what I see roll through the doors!!!! - PawPaw_n_GramExplorerLast time I bought tires - I wanted to see the date code on each tire before it was mounted, refused one tire. They got a newer tire for me. (Like most retailers - tire companies want to sell the oldest item in their inventory first.)
I then told them to mount the tires with the date codes on the outside. After they said the job was finished, I made them remount one which had the code on the inside. - Cummins12V98Explorer III
I did have them mount my date codes to the outside on my new Motorcycle trailer tires. - dodge_guyExplorer IIIt doesn't really matter unless the tire is asymmetrical or directional.
There are 2 ways to look at it. On the outside it's easier to read. But on the inside it protects it from getting ground off from curbs, although that shouldn't be an issue on a trailer. - fj12ryderExplorer III
Old-Biscuit wrote:
I always figured it was a 50/50 chance whether the date code was inside or outside. I have some inside, some outside. I don't think the mounters pay much attention, unless they're trying to sneak some old tires passed you. :)
Yep......
Date codes are only on one side of tire
And when tire is mounted..it's on the inside! - Dutch_12078Explorer IIII don't know if it was done deliberately or not, but all the date codes on our coach are on the outside, making them all readable with minimal effort. Well, all except the spare anyway...
- Old-BiscuitExplorer III
Blazing Zippers wrote:
Hey! I just found the answer!!! I gotta look on the other side of the tire.
Yep......
And when tire is mounted..it's on the inside! - Blazing_ZippersExplorer IIHey! I just found the answer!!! I gotta look on the other side of the tire.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 21, 2026
