jspringator's avatar
jspringator
Tried something new last trip.
I have a 2001 Ford Excursion V-10 with 4.30's. I tow with a small dual sport (230 cc) on the front of the truck. My TT is high profile and 33' in length.
I experimented with locking out OD, and setting the cruise at 58. WOW, what an easy tow. I was running just under 3,000 rpm and it pulled every interstate hill with no downshifting Gas mileage was around 7.8. It was getting around that before. Oil consumption was the same. A quart to Florida and a quart home. I'm guessing 2,900 rpm is a high torque area of the power curve.
If I don't use cruise my speed picks up so much it kills the mileage, although I'm sure it would do 65 with ease.
  • There is a button on the end of the shifter. When pushed, it prevents the transmission from shifting into overdrive, or 4th. It still "locks" in third. The 2001 2 valves have no tow haul mode, (except maybe what I did) and have less power than the later 3 valve models. The Excursion also weighs quite a bit more than the F-250.
  • When you say "locking out OD" do you mean putting it in Tow mode? When we had a TT, we towed it with an F250 V10 6.8L with a 4.3 axle and it towed very well.
