Groover
Jul 07, 2017Explorer II
Trouble with a Titan XD
This is the worst review that I have seen so far on the Titan diesel. I hope that it is an isolated case: http://www.caranddriver.com/reviews/2016-nissan-titan-xd-long-term-test-review
ShinerBock wrote:N-Trouble wrote:
Told ya so. 1/2 ton diesel just a bad idea IMO. Most get used as commute vehicles/grocery getters which is not great for a DPF equipped truck. These DPF diesel motors need to be worked. Those that get worked seem to have less emissions related issues.
The Nissan Titan XD is not a "1/2 ton" per its GVWR which is what determines if is a "1/2 ton" or "3/4 ton". In fact, it has a GVWR 8,600-8,990 lbs depending on the configuration which just 210 lbs less than 9,200 lbs GVWR of a 2009 GM 2500HD. My friends 2002 GM 2500HD has a GVWR of 8,600 lbs. Is his is 2500HD considered a "1/2 ton"?
