Groover
Jul 07, 2017Explorer II
Trouble with a Titan XD
This is the worst review that I have seen so far on the Titan diesel. I hope that it is an isolated case: http://www.caranddriver.com/reviews/2016-nissan-titan-xd-long-term-test-review
Ralph Cramden wrote:
I have been under one while it's been up on a lift, as well as an F250 or two, GM's 2500HD's, and a Dodge 2500 once or twice.
Yes.....the axles......The big 3 have floaters in the rear and the Nissan semi floating. If we are talking definition, when the semi floaters axle snaps, off go's the wheel, and when the floaters axle snaps you keep going. The axle carries the weight on the semi floating, on the floating all the axle does is provide rotational torque, the entire rear end carries the weight. I believe the Nissan has a rear axle weight rating of 4900. I don't know the Dodge or Ford from memory but my GMC is 6200.
Nissan touts a 14" and change diameter rotor, but it stops there. All the big 3 use much more substantial pads and calipers, rotor size non withstanding.
The frame. Much more substantial on the big 3. No comparison can be made on the rest of the driveline or suspension components either from soup to nuts.
Calling them 1/2 ton, 3/4 ton is all outdated terminology going back to the day a 1/2 ton could haul 1000 lbs, and a 3/4 ton could haul 1500. Since my GMC 2500 has a payload of 2835 I guess I could call it a 1-13/32 ton.
