l001952119
Sep 03, 2013Explorer
louiskathy wrote:
Ours got clogged with sand three years ago in CA. Never did get it to work after that. How do we know it's sand? We filter the water prior to it coming into the rig but we never thought about filtering the water when we flush the tanks. Duh. The filters were full of sand so it's a no brainer that the sprayer got clogged at the same campground.
I experienced the same basic problem. My use of well water at some campgrounds allowed small pebbles, shale, etc. to enter the flush system. This plugged the small orifices in the spray head. This can be prevented by using a screen washer in each water hose inlet fitting. I had an enclosed bottom shield and had to cut a hole in the tin and replace the nozzle. It's a guess where the head is located and can result in alot of incorrect cuts and patching!
