marobrown's avatar
marobrown
Truck alingment
I'm am preparing to get new tires on my truck, and am going to have an alignment done at the same time. The tires I am running now were installed in 2008, and have 102,000 miles on them. The inside of the tires is noticeably worn more that the rest of the tire, I'm thinking this is from the truck being aligned empty and getting thrown off when I haul my trailer. No belts showing or anything like that, just can see there is no longer any tread on the inside, just smooth, I have been able to keep this even over all 4 tires throughout the life by rotating them every other oil change. Since 2011 my truck hasn't been a daily driver anymore, and has had around 35,000 miles out on it. Roughly 20-25k while pulling. I am thinking of having the truck aligned with a 1-2 hundred pounds of weight in the bed to simulate a closer situation of my stance when towing more than empty, or in between. Has anyone ever done this and if so what were the results. Thanks in advance.
  • I'm no expert at all but my reasoning is if this were an alignment issue you would never have gotten that many miles from the set of tires. I also can't understand how weight pressing down on the truck suspension would cause inside wear on every tire unless grossly overloaded. I would suggest this is an air pressure adjustment that needs to be made for that particular make/set of tires. Hoping an expert comes along with an expert opinion.
