Camper_Jeff___K's avatar
Dec 03, 2017
Truck Camper - RV Leak Check In The Rain 12 02 2017
VIDEO: Truck Camper - RV Leak Check In The Rain 12 02 2017
An Update on the performance on the recent Drip Rail over the dinette window installation.
We're having a good rain storm tonight. I went out to check on the Truck Camper as usual when there's a good rain going. The newly installed drip rail over the side dinette window is doing it's job nicely, keeping water from flowing like a river over the window causing wetness inside. You can see the volume of water involved and how the drip rail is deflecting it.
The inside is dry...
  • I went to the auto parts store and bought window vents that attach with 3M tape. That works pretty well.
  • Good job Jeff. I’ve had to do that to some of the campers I’ve owned in the past. Sliding windows have been the most leak prone in my experience. My current camper has crank out, jalousie type windows and so far they haven’t needed a drip cap.
    Another option to use are these molded aluminum drip caps that come in various lengths. They aren’t as rugged as your angle aluminum though, and can be bent easier, and probably need a little more clearance than you have under your awning arm.
    Drip Cap
  • Nice job. Sometimes a little overkill is a good thing, especially when it gets the job done.
    Keep us updated on it's performance.
  • work2much wrote:
    That's cool although angle metal seems like overkill to divert water around a window. The Window was leaking before? Was it not sealed properly? Are the other windows in the camper flashed/sealed differently to avoid water intrusion? Was the water accessing through the operable separation of the surfaces of the window or the seal of the window to the camper?
    In any case glad you stopped the leak!
    The dinette window is sealed the same as all the other windows. None of the others have been problematic. I think one possibility is that the flood of water was flowing down the window over the weep holes at the bottom of the window frame. It may have been able to back up in through there to the inside but I never noticed it happen. I did notice the bottom of the window frame had an accumulation of water in it which I figured to be condensation a couple times.
    This window had been sealed a couple times and it continually failed possibly from body flex or unknown other forces. It has passed the test of a few good rains now without failure with the drip rail so I'm happy. This is the second location on the TC where all other attempts to stop a water leak failed and the aluminum angle drip rail resolved the leak problem as yet permanently in the first case and so far so good in this case.
    If it does fail, I'll be back to talk about it. Full disclosure...
  • That's cool although angle metal seems like overkill to divert water around a window. The Window was leaking before? Was it not sealed properly? Are the other windows in the camper flashed/sealed differently to avoid water intrusion? Was the water accessing through the operable separation of the surfaces of the window or the seal of the window to the camper?
