Slackjaw wrote:
How do I know if I need upper or lower stable loads, air bags, timbrens, etc...? Why not just add a leaf spring if weight is an issue? (This truck is only a part-time daily driver; I bought it to downsize from a Class C to a t/c. I couldn't afford an F350, or I would have bought one. I bought the least expensive non-white color truck I could afford. Didn't have another $10k to drop to get a non-white F350. My previous truck was white--NOT the preferred color for living in Alaska!! :D )
Guess I should by the t/c and go from there?
nomadictxn--that's something along the line of what I'll be looking at. Looks like your truck has the same tires I have too.
Im carrying a Lance 981 on a 2011 f350 6.2 SRW 4x4 crew with a 4.1 rear. The Lance weighs in the 4k range loaded to go. No power issues whatsoever. Im comfortable with the handling. The mods I have done; airbags, Rancho 9000xls , superswaystop bumpers. I could do without the airbags if forced but the combo effect of the Rancho shocks and swaystop bumpers are something I'de definitely miss. If you can find a TC that's weighs in at 3500 #s loaded you'de be even happier.
