Bedlam
Oct 13, 2015Moderator
I have a 5x8 flat bed trailer with a 3500 lb single axle and 225/70R15 tires. I would not have an issue using it to move 4000 lbs around at low speeds, but would not use it for roadway transport or a permanent support. It would be perfect for positioning a camper and then pulling it clear when done so you can lower the camper to its lowest jack positions. You should be able to find a new trailer like this for under $1500 or less for a used one.
44,066 PostsLatest Activity: Apr 10, 2026
