zcookiemonstar
Oct 13, 2015Explorer
I used four of those Harbor Freight jacks to try and move a shed. I made up some brackets with steel tubing flat plates and angle iron. I also cut the bottoms off the jacks and made a taller wider one to be able to use ten inch tall tires (wheel barrow tires). It worked great to lift the shed but it did not move well the tires did not want to follow they just went in every direction. This was on soft uneven dirt/grass. I think it would have worked better on a harder flatter surface and if two of the wheels did not swivel. This was a 8x8x8 wood shed and it was empty.
44,066 PostsLatest Activity: May 13, 2026
