Oldtymeflyr
Oct 14, 2015Explorer
I would skip the jacks, you can level with plywood boards for the purpose.
As far as moving the camper support, which it is more than a "dolly" in the sense that you are not using the "dolly" to move the camper, but just to support the camper off of the truck, put some 8" to 10" balloon tire casters, on the side of the support and tip the dolly over onto the casters to move it around.
Ours is steel, welded together. If I made it again, it would be a combination of welded ends with the sides being bolted together, just to make it easier to store when the camper is off the dolly. I may make this modification this winter.
Good Luck.
Rick
Good Luck.
Rick
44,066 PostsLatest Activity: May 16, 2026
