Powerdude
Jan 21, 2015Explorer
Forget about your GVWR, that takes into consideration tire capacity, and tires can be easily upgraded.
What can't be upgraded (easily), are your axle ratings, GAWR, "A" stands for axle. It's also on the door. One for the front, and one for the back.
Total those up, subtract the weight of your passengers and cargo, and that's your weight carrying capacity.
If you exceed your axle ratings, you'll prematurely wear out your axle bearings, which can have a catastrophic failure (again, in theory).
Your rear axle is a semi-floating axle, which means it probably cannot carry a 4000 lbs camper.
But, 4-wheel and Outfitter are definitely doable. Pretty sure 4-wheel Campers can just make you an empty shell if you want.
44,071 PostsLatest Activity: Aug 23, 2026
