Moz's avatar
Moz
Truck Camper leveling while attached to truck
On the subject of leveling I have Googled the subject and not found an answer. Here are a couple of useful pages I have read.
http://www.truckcampermagazine.com/question-of-the-week/level-your-truck-camper/
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/25883723/print/true.cfm
Before I ask my question I would like to post a hypothetical scenario to frame the question. So if you are an engineering type, please read both parts if you can help me.
Hypothetical: - If I have the camper attached to the truck using Torklift basic springload turnbuckles and I use the jacks to lift all four corners, eventually I would expect to see the springs begin to show (visibly by extending slightly) the extra strain when the jacks start to lift the truck bed. (Not a good idea.)
Question: - Would I be correct in assuming that if there is no visible movement of the spring, then there is no extra load on the spring (Hooke's law)? And, if so, is there no extra load on the jacks above the normal weight of the camper? ie - is the camper still be lifted by the truck suspension?
With the hypothetical out of the way:-
Real scenario (after considering the above): -
If the camper is parked at a slight angle, and one uses the jacks to lift the camper (still attached to truck) to level the camper, and there is no visible extra strain on the turnbuckle springs, is there any extra load on the jacks beyond the weight of the camper?
Supposition: - The way I see it, it is safe to assume that if there is no extra extension to the springs then there is no extra load on the jacks? Am I wrong, and if so, why?
Clearly it would be better to use blocks to level the truck as much as possible but the question relates to the supposition above.
Thoughts?
Thanks,
Moz
