Better solution...
Wire the trailer power to an 800W HF inverter, power the trailer's inverter/charger with the 120 VAC inverter output.
The inverter will not drop out unless the source voltage drops below ~10.5 volts.
Controlled (re-)charging rate for the trailer battery(s).
Enough AC power for the fridge...
Charging a deeply discharged battery from the trucks FIXED voltage source will seriously shorten battery life.
Ask anyone having charged series 6V deep cycle batteries from an automotive alternator/VR system.
Boils the electrolyte.
