DondupExplorerSep 02, 2017truck camper tie downHi, I'd like to know if I use 3000 lbs (ratchet type) tie down belts with my camper, is it strong enough or legal on the road? Thanks
jimh406Explorer IIISep 02, 2017It's probably legal, but I think you'd be better off with spring loaded tie downs. If you tighten the straps too tightly, you can damage the frame. Some manufacturers recommend frame mounted tie downs. I think there must be a reason for it.
Related ContentAm I a Truck Camper?Truck camper matchNew Truck Camper Forum CommentsTruck Camper Tie DownsTruck camper towing a boat
