Grit_dog
Nov 02, 2016Trailblazer
Ditto. My 860 published weight on the tag is like 3300lbs iirc. Never weighed it, but doing some math on the pressure in the airbags to restore ride ht puts it over 4000lbs and I believe it. Probably closer to 4500 full of stuff and on the road.
I don't fault the mfgs as they likely publish "dry" weight. Hard options should be included, but Everything else including propane, water and anything that wasn't in the camper when it was hitting the end of the assembly line is added on
44,068 PostsLatest Activity: Jun 01, 2026
